It is currently Fri May 01, 2026 2:30 am
 Post subject: Non-Electricians Removing Dead Front Panel Covers for IR Sca
PostPosted: Wed Nov 29, 2023 7:40 am
Has anyone used non-electricians to remove dead front panel covers for IR Scanning? We are considering this, and would provide the proper Arc Rated PPE and training. Any thoughts are greatly appreciated.
 Post subject: Re: Non-Electricians Removing Dead Front Panel Covers for IR
PostPosted: Wed Nov 29, 2023 8:28 am
Suggest using qualified personnel to remove the covers one time to install IR windows to eliminate the hazard going forward.
PostPosted: Wed Nov 29, 2023 2:29 pm
If they are properly trained, per the employer's electrical safe work program, then they become qualified to perform a specific task.
NFPA70E does not use the term electrician. Few companies have an 'all or none' qualification process.
