It is currently Mon Nov 23, 2026 12:40 pm
PostPosted: Thu Mar 22, 2012 10:19 am
@phil Sander..I agree with you!! SKM have terrible settings for Relay!! You have to select two different relays for phase and ground...I would highly recommend ETAP!! Excellent interface easy to use and a very good library. Though their customer support is bit wired, they take time to answer your question specially in the case when you need a new library..
PostPosted: Thu Mar 14, 2013 8:13 am
For the data collection part start with "FlashTrack" for the data collection. It is easy to use and a qualified worker can quickly collect all the data needed for the engineer it do the analysis using (in our case) SKM.
Note: FlashTrack is not for doing calculations, it was designed for the qualified worker to capture the data needed to model the system.
Bryan Rupert
[url='http://facilityresults.com/W1/']Facility Results[/url]
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
