| Fuse - can't view TCC https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=1290 |
Page 1 of 1 |
| Author: | Sylvain.Belec [ Fri Sep 17, 2010 11:39 am ] |
| Post subject: | Fuse - can't view TCC |
Hi, I am using ETAP 7.1 with the server license and have problems with fuse tcc. I have big problems seeing fuse TCC. Sometime everything works fine but other time, when i try to view the same fuse tcc, it is simply showing a blank page. Even when I manually trace a tcc, it will sometime work, other time not. Breaker and relay tcc are working fine. It is causing me problems because when it shows me a blank page, the fuse is not taken into account when performing Arc flash analysis... Anyone got that problem ? thanks. |
| Author: | geh7752 [ Sat Sep 18, 2010 5:00 am ] |
| Post subject: | |
Sounds like the fuse isn't selected. Make sure the fuse is selected in the OLV before running the tcc. |
