It is currently Sat May 02, 2026 3:30 am
 Post subject: Comprehensive Short Circuit Studies
PostPosted: Sat Aug 03, 2019 9:24 am
How does SKM Software calculate the bolted fault current for arc flash studies? What are the steps of calculating short circuit current by using comprehensive short circuit studies?
 Post subject: Re: COMPREHENSIVE SHORT CIRCUIT STUDIES
PostPosted: Mon Aug 05, 2019 9:15 am
I would suggest that you read the user guide SKMInclude_PTW Userguide.pdf and tutorial SKMInclude_PTW Tutorial.pdf. There is a ton of information that will educate you on how the calculations are done. If you have a valid Maintenance Agreement and are up to date with your maintenance fees, then you can go to their website and down load these two documents.
