What do you guys use to collect data?
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=5800
Author:  jsoar [ Wed Jun 12, 2024 8:01 am ]
Post subject:  What do you guys use to collect data?
I am trying to find a good whiteboard app to use to collect data. We are currently using freeform on the Ipads and it starts lagging when there is alot of data.
Author:  bbaumer [ Thu Jun 13, 2024 3:40 am ]
Post subject:  Re: What do you guys use to collect data?
If it is a small job and I have as-built drawings and submittals I normally model it first before I go to collect/verify the data and just work off a hard copy printout and mark it right on the drawing.
If I don't have any drawings or it is too large to work off plots of the model I use a Notability on my ipad.
Examples below. I don't use the SKM mobile version. Never even checked it out. Probably should.
Author:  bbaumer [ Thu Jun 13, 2024 5:44 am ]
This is weird. The preview thumbnails don't match the pics. If you click on the pics they are correct though.
Author:  jsoar [ Thu Jun 13, 2024 6:39 am ]
I have Skm mobile but haven't used it yet. A lot of the data collection I've been doing has been done on Easypower. I have attached an image of how I've been doing it.
Does Notability allow for multiple users at the same time?
Author:  bbaumer [ Thu Jun 13, 2024 9:48 am ]
Not that I know of RE: Notability. It is basically just a scratch pad you can add pictures and PDF's to and mark over the top of. I sometimes copy drawing PDF's into Notability and make notes on the drawing that way instead of carrying paper.
Author:  Steven.J.Abbott [ Mon Jun 17, 2024 9:51 am ]
REALTIMEais.com is the most complete and easy to use system for online or offline methods...
with large system it invaluable for being able to start stop at any devices and not lose track of or make alerts for items that require special needs or considerations.
