It is currently Mon Nov 23, 2026 2:10 pm
 Post subject: OSHA SubPart S
PostPosted: Fri Apr 11, 2008 7:17 am
Here's a good one....
I just read on the website for The Workplace Safety Awareness Council that the August 2007 Revision on the 29CFR1910.301-.399 requires arc flash hazard boundaries, equipment labeling and PPE. Can anyone confrim this? I am trying to find a place to purchase the standard, but so far I can't find a place to do that. The above mentioned website is linked below.
http://www.wpsac.org
PostPosted: Wed May 21, 2008 9:02 am
That would be an earth shaker. If you find this, please post it here.
Thanks!
PostPosted: Mon Jun 02, 2008 8:55 pm
You were misinformed (Too bad ti should be) the Aug revision adopted the installation section of the 70E, not the safe work practices, that is coming soon, I heard Feb 2008 but we are way past that already.
PostPosted: Thu Jun 12, 2008 7:06 am
You can get PDF's of specific CFR sections via this website:
http://www.gpoaccess.gov/cfr/retrieve.html
Also, here is a link to the 2005 Federal Register where OSHA proposed changes to it's utility standard 1910.269 to add arc flash requirements:
http://frwebgate.access.gpo.gov/cgi-bin/getpage.cgi?dbname=2005_register&position=all&page=34866
To my knowledge, these changes have not been adopted into 1910.269. I bet they are still being litigated.
 Post subject: Re: OSHA SubPart S
PostPosted: Wed Dec 24, 2014 12:15 am
It seems 1EEE 1584 provides guidance in cutting off calculations at 2.0 seconds of arc exposure. I provide training as such and caution the workers that for certain job tasks/approaches this assumed time constraint may not be valid.
