| Author |
Message |
KarenMajala
Post subject: Transformer Taps/LTC Posted: Mon Nov 17, 2025 11:01 am |
Hi, I am new to arc flash modeling and was wondering what was best practice when dealing with transformers with OLTC (automatic on load tap changers). Is it best/common practice to run arc flash cases using the optimal LTC determined using the system load flow, or by using the max/min LTC parameters?
| Top |
mpparent
Post subject: Re: Transformer Taps/LTC Posted: Thu Nov 20, 2025 12:12 pm |
If this were my project, I would model the normal operating mode tap initially. Then I would model the extremes to see if there is any worse case variation. That would give me some indication if I should continue w/ intermediary taps.
This becomes a question for the user on how frequent the OLTC varies from nominal...it might end up that you don't need to model any other taps if the frequency of use is low. Just depends on operating conditions, etc.
Just my opinion...
| Top |
[ 2 posts ] |
