It is currently Wed Sep 23, 2026 6:55 pm
 Post subject: Transformer Taps/LTC
PostPosted: Mon Nov 17, 2025 11:01 am
Hi, I am new to arc flash modeling and was wondering what was best practice when dealing with transformers with OLTC (automatic on load tap changers). Is it best/common practice to run arc flash cases using the optimal LTC determined using the system load flow, or by using the max/min LTC parameters?
