It is currently Mon Sep 21, 2026 7:38 am
 Post subject: "sufficient durability to withstand the environment involved
PostPosted: Wed Mar 04, 2026 10:14 am
Section 110.21 (B) is quote above in the title and is required for field applied Arc Flash Labels.
What Tips & Tricks do you guys use to address this requirement for labels installed outside and/or exposed to sunlight? We have been using a clear, UV resistant paint sprayed over the labels. But recently I saw a label we installed in 2022 and it was 75-90% disintegrated!! This makes me second guess this method, looking for other options.
Thanks in advance!
 Post subject: Re: "sufficient durability to withstand the environment invo
PostPosted: Thu Mar 05, 2026 3:11 am
I print indoor labels on a color laser printer and they work fine for that BUT I have the same issue as you with outdoor labels. They fade out very quickly. The label stock isn't the problem, it's the color laser printer ink that doesn't hold up.
I have to get someone to print outdoor labels to a Brady printer. Those hold up very well.
