It is currently Tue Nov 17, 2026 10:46 am
 Post subject: Overduty Equipment
PostPosted: Thu Apr 09, 2026 6:22 am
I usually run my short circuit study using the ANSI standards and there are several over duty devices (about 20 devices). For arc flash, I run comprehensive method which results in only about 3 devices reported as over duty.
Would you only print the 3 over duty labels in comprenhsive or for this case would you run ansi arc flash? All equipment is 480 and 208V
 Post subject: Re: Overduty Equipment
PostPosted: Thu Apr 09, 2026 7:30 am
Hmm, you are correct. It was a user error, apparently there were some errors when I ran the SC eval and comprehensive wasn't updating. They are both showing the same now, thanks for the response. I would delete this post if I knew how LOL
