It is currently Mon Nov 23, 2026 10:42 am
 Post subject: Extension Cord Fault
PostPosted: Tue Jun 20, 2017 9:38 am
Using the extension cord as a disconnect for a 1/2HP motor caused the cord to catch on fire. GFCI or circuit breaker feeding the cord did not trip. 120VAC.
File comment: Cord Fault
 Post subject: Re: Extension Cord Fault
PostPosted: Mon Jun 26, 2017 8:21 am
Probably caused by excessive resistance at plug vs. over amperage. This would result in more heat than could normally be dissipated by the plug until it ignited.
PostPosted: Mon Jun 26, 2017 8:28 am
Yeah, and there appears to be little to no damage around the ground pin, so it looks like a GFCI might not have noticed this event at all.
