It is currently Fri Jul 31, 2026 11:16 am
 Post subject: All You Ever Wanted to Know About GFCIs & AFCIs
PostPosted: Fri Apr 05, 2013 4:20 pm
Location
https://event.on24.com/eventRegistratio ... e=register
United States
See map: [url='http://maps.google.com?q=%2C+%2C+%2C+%2C+us']Google Maps[/url]
[url='http://event.on24.com/eventRegistration/EventLobbyServlet?target=registration.jsp&eventid=602365&sessionid=1&key=B4ED1DD0EA2C2C4780E35A663E04453C&partnerref=web&sourcepage=register']Image[/url]
Learn what you need to know through this live presentation with NEC expert Mike Holt.
Ground fault circuit interrupters (GFCIs) are designed to disconnect power to a branch circuit whenever the unit detects an imbalance of current between the energized conductor and the neutral conductor. Since the 1970s, GFCIs have saved thousands of lives and helped cut the number of home electrocutions in half. In recent years, the NEC has expanded the requirements for these devices to many other areas outside the home.
Introduced in the 1999 edition of the NEC, arc fault circuit interrupters (AFCIs) provide enhanced protection against fire hazards in the home known as arc faults. An arc fault is a dangerous electrical problem caused by damaged, overheated, or stressed electrical wiring or devices. Without AFCIs, arc faults can create dangerous fire situations within the hidden spaces of dwelling units.
In this webinar, Mike will not only explain the current NEC requirements for GFCIs and AFCIs, but he'll explain how they operate, what causes their premature failure, and when they won't provide the safety protection you might have thought they would. [url='http://event.on24.com/eventRegistration/EventLobbyServlet?target=registration.jsp&eventid=602365&sessionid=1&key=B4ED1DD0EA2C2C4780E35A663E04453C&partnerref=web&sourcepage=register']REGISTER TODAY![/url]
[url='https://event.on24.com/eventRegistration/EventLobbyServlet?target=registration.jsp&eventid=602365&sessionid=1&key=B4ED1DD0EA2C2C4780E35A663E04453C&partnerref=web&sourcepage=register']
[color=rgb(255, 255, 255)]CLICK HERE TO REGISTER FOR WEBINAR[/color]
[/url]
[color=rgb(153, 153, 153)]Sponsored by: [/color]
[url='http://www.wheatland.com/']Image[/url]
[url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:yIl2AUoC8zA']Image[/url]
[url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:V_sGLiPBpWU']Image[/url] [url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:7Q72WNTAKBA']Image[/url] [url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:qj6IDK7rITs']Image[/url] [url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:gIN9vFwOqvQ']Image[/url] [url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:l6gmwiTKsz0']Image[/url] [url='http://feeds.feedburner.com/~ff/ECMMostRecent?a=lAlguzY8YkA:W-_kWMVwpBo:I9og5sOYxJI']Image[/url]
[url="http://feedproxy.google.com/~r/ECMMostRecent/~3/lAlguzY8YkA/all-you-ever-wanted-know-about-gfcis-afcis"]Continue reading...[/url]
Arc Flash Forum News Feed
