Arc Flash Forum
Arc Flash – Modeling Enclosure Size
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=5471
Author:  Jim Phillips (brainfiller) [ Sun Jun 27, 2021 12:57 pm ]
Post subject:  Arc Flash – Modeling Enclosure Size
As many know by now, the 2018 Edition of IEEE 1584 provides a method to adjust the incident energy based on the size of the enclosure opening.
Table 8 – Classes of equipment and typical bus gaps contains enclosure sizes for different voltages and classes of equipment.
Most software defaults to these values in the absence of user specified sizes.
Here is this week’s question:
Do you use/specify default enclosure sizes or actual enclosure sizes for arc flash studies?
Default sizes
Actual sizes
A mix
Not sure
Not involved with studies
http://www.phpbb.com/
