It is currently Mon Nov 23, 2026 9:45 am
 Post subject: Windows 10 Professional 64bit OS
PostPosted: Thu Apr 28, 2016 12:37 pm
Has anyone been running Windows 10 Pro 64 bit with SKM and EasyPower? Feedback?
 Post subject: Re: Windows 10 Professional 64bit OS
PostPosted: Fri Apr 29, 2016 5:18 am
Same question for 32 bit, not to hijack the thread.
PostPosted: Mon May 02, 2016 1:21 pm
I run SKM version 7.0.4.6 without problems on windows 10. I think the only problem I had was getting the computer to recognize the green usb key. This was fixed by downloading the updated HASP install file on the SKM website. Other than that, I didn't see any differences than SKM on windows 7 64bit.
PostPosted: Tue May 03, 2016 11:27 am
I've had some stability problems with Windows 7, 64 bit, running inside a VM irrespective of the host operating system or VM platform. There are some performance problems with Windows 7, 32 bit inside a VM but no stability issues that I've found although over time this situation is getting better. With XP or the various flavors of NT stability and performance are not an issue inside a VM environment. This is all independent of the applications that are running on whichever Windows flavor you choose to run within the VM.
