It is currently Mon Nov 23, 2026 11:03 am
 Post subject: Confusion when to wear PPE
PostPosted: Tue Nov 03, 2009 1:58 pm
If the energized 480V panel has a deadfront cover and has an HRC of Cat
2 or Cat. 3, is PPE required to close or open a branch breaker?
What is your NFPA 70E interpretation?
PostPosted: Tue Nov 03, 2009 2:52 pm
Yes it is, that is "interaction" with equipment. Obviously you are using the tables and should follow the HRC for that task
