Shock Protection Approach Boundary Inquiry
https://brainfiller.com/arcflashforum/viewtopic.php?f=7&t=5453
Author:  wfg42438 [ Mon May 10, 2021 11:37 am ]
Post subject:  Shock Protection Approach Boundary Inquiry
Hello Everyone,
As many of you are aware documents like NFPA 70E 2021 publish shock protection boundaries for energized equipment(See image sampled from NFPA 70E).
After doing some research I saw that there is more than one document out there with shock protection boundary recommendations.
Some examples of documents which also publish Shock Approach boundaries are listed below:
Brazil: NR-10
(http://www.braziliannr.com/brazilian-regulatory-st...)
Canada: Z462
Great Brittan: EN 501110-1:2013
Im curious if anyone out there knows if there is an Australian document or standard which also publishes its own shock protection boundaries too?
Any help with this inquiry would be much appreciated!
File comment: NFPA 70E
Shock.tif
Author:  Larry Stutts [ Thu Jun 24, 2021 5:41 pm ]
Post subject:  Re: Shock Protection Approach Boundary Inquiry
wfg42438 wrote:
Hello Everyone,
Brazil: NR-10
Canada: Z462
I would just use the NFPA 70E (but of course I am in the US); however, if I had data from other sources, I would use whatever source published the most conservative boundary.
