It is currently Wed Apr 29, 2026 2:58 pm
Do you believe switches should be open to view the blades even when the line side is energized?
Yes 31%  31%  [ 15 ]
No 31%  31%  [ 15 ]
It Depends 39%  39%  [ 19 ]
Total votes : 49
 Post subject: Electrically Safe – Visually Verify Blades
PostPosted: Sun Apr 10, 2022 3:06 pm
120.5 Process for Establishing and Verifying an Electrically Safe Work Condition
(3) Wherever possible, visually verify that all blades of the disconnecting devices are fully open..
Viewing the disconnect blades is easy if the switches have viewing windows. However most switches do not have windows. In a recent discussion, the subject came up regarding opening disconnect switch covers to view the blades - it was an interesting exchange. An obvious issue is the line side would likely be energized and exposed. Also, remember most equipment is old/legacy equipment.
Here is the question:
Yes
No
It Depends
 Post subject: Re: Electrically Safe – Visually Verify Blades
PostPosted: Wed Apr 15, 2026 12:11 am
For long-term use, consistency is key. I tried Gambloria Casino for a while and noticed that it performs steadily without glitches or unexpected issues. That’s something I always look for because it shows the platform is reliable. In Canada, experienced users often recommend choosing platforms that maintain quality over time rather than just offering short-term incentives, and I completely agree with that.
