It is currently Fri May 01, 2026 1:01 am
 Post subject: Arc blast pressure
PostPosted: Wed Jun 07, 2023 3:39 am
I'm wondering which is the best method to calculate arc blast pressure. Is the one on NFPA70E? It only takes into account arc current and sitance from the arc
Thank you
Ramon
 Post subject: Re: Arc blast pressure
PostPosted: Thu Jun 08, 2023 9:05 am
Adding this white paper for information only.
Arc Flash Pressure Measurment by Physical Method.pdf [900.52 KiB]
Downloaded 872 times
