| Author |
Message |
RECS
Post subject: Where to disconnect power for an ESWC Posted: Tue Oct 08, 2024 10:10 am |
Joined: Sat Apr 04, 2009 9:50 pm Posts: 122 Location: San Antonio, TX
To achieve an ESWC, all sources of electrical power that supply electrical equipment need to be disconnected.
I understand we cannot use the main overcurrent protection device from the electrical equipment, but an upstream disconnecting means.
Otherwise, you will still have power to the electrical equipment on the line side of this main overcurrent protection device.
I can't find a reference to this in the NFPA 70E. Where does it specifically say that we can't use the main OCPD of the electrical equipment to disconnect the power to this equipment?
| Top |
bbaumer
Post subject: Re: Where to disconnect power for an ESWC Posted: Wed Oct 09, 2024 5:27 am |
| Arc Level |
Joined: Fri Jul 08, 2016 10:01 am Posts: 488 Location: Indiana
| Top |
[ 2 posts ] |
