| Exclude from arc flash by default? https://brainfiller.com/arcflashforum/viewtopic.php?f=15&t=5356 |
Page 1 of 1 |
| Author: | aguywithfeet [ Tue Sep 01, 2020 5:33 am ] |
| Post subject: | Exclude from arc flash by default? |
I am new to the SKM software and it seems that for some reason the software is automatically clicking exclude from arc flash bus calc and the other check boxes. Like when you click node bus, but these buses were never nodes buses and they were not cloned from one. Is there a setting i am missing that is causing this? |
| Author: | pvheesch [ Fri Sep 04, 2020 10:21 am ] |
| Post subject: | Re: Exclude from arc flash by default? |
Agree with calling SKM support. I can't find anything in options, in a file, or a registry entry that would fix that. That said, SKM support is usually quite helpful. |
| Author: | mayanees [ Mon Sep 14, 2020 9:43 am ] |
If you do Project Options/One Line you have control over that for Auto-generated buses. But like everyone has stated, use their Tech Support group. Of course that means you need to be paid up on your maintenance fees. |
