It is currently Mon Nov 09, 2026 8:39 am
 Post subject: Auto-transformer connected to ungrounded delta
PostPosted: Tue Jan 29, 2013 12:32 pm
I need to temporarily power up some 400 Volt equipment before it ships to Europe. I have access to a 480 to 400 volt auto-transformer but I read on temcotransformer.com's website that "Auto transformers should not be used in closed delta connections or they will introduce into a circuit a phase shift which causes higher power use."
My plants electrical supply is a 480 volt ungrounded delta. I have not been able to find any additional information on this subject. I was wondering if anyone has any knowledge about this.
If the worst issue is a small increased power use I'm not too concerned as this is only temporary. I would just like to know how much increased power and if there are any other issues to consider.
PostPosted: Wed Feb 06, 2013 3:43 pm
As long as the kVA is correct you should not have any issues if you are discussing a factory assembled auto transformer.
