MasterFormat 2012 - Numbers and Titles
https://brainfiller.com/arcflashforum/viewtopic.php?f=2&t=2437
Author:  MattB [ Thu Sep 13, 2012 11:50 am ]
Post subject:  MasterFormat 2012 - Numbers and Titles
CSI (the Construction Specifications Institute) publishes the MasterFormat list to standardize the organization of construction specifications.
Where does an arc flash spec belong according to this standard? There is a designation for "Overcurrent Protective Device Coordination Study" (26 05 73) which I will probably use.
What CSI number does your organization use for arc flash specs?
Author:  MattB [ Fri Sep 14, 2012 12:24 pm ]
FYI, after further googling, it appears that arc flash studies are generally placed in section 26 05 73.
Author:  gilmomoney [ Mon Sep 17, 2012 3:25 pm ]
Matt,
we've been using 26 05 70 as a catch-all for our studies (arcflash, coordination, harmonic, short-circuit, load-flow & voltage-drop, power factor correction). if I was starting from scratch though, i'd probably go with 26 05 73.
mike
Author:  Hurwitz [ Mon Sep 24, 2012 10:05 am ]
Matt,
We use 29 05 93 APPARATUS COORDINATION, INSPECTION, AND TESTING. Like Gil, we put all the studies in there. Our reasoning is that one company is going to create a model and do all the studies so we may as well save virtual ink rather than repeat the same requirements in different sections. Unless your client has a standard, you could use any section number that makes sense. The CSI titles are a beginning, not an end.
