 Post subject: Insulating feeder wires/term points in a switchboard/panel
PostPosted: Wed Jan 04, 2023 12:33 pm
I was wondering if a Switchboard or Panelboard has its feeder wires insulated and termination points shielded with plastic/insulation, then the Arc Flash rating of the switchboard/panelboard should be the same as though nothing was insulated?
The cal/cm2 number would not change. I'm thinking the insulation might protect against a shock, but not an Arc Flash explode.
Just asking if this assumption is correct.
