It is currently Mon Nov 23, 2026 7:45 pm
 Post subject: How to model a Fused circuit breaker in SKM
PostPosted: Tue Aug 13, 2024 8:13 am
How do I model a Fused circuit breaker in SKM? The breaker is 800A Cutler-Hammer DSL-206.
 Post subject: Re: How to model a Fused circuit breaker in SKM
PostPosted: Tue Aug 13, 2024 3:19 pm
Looks like you have an Eaton Magnum DS with current limiters. Just put the breaker and current limiting fuses in series with each other. Here is an example but I don't know exactly which breaker you have or what the amp rating is of the limiter so I just somewhat randomly picked them. This is in SKM.
PostPosted: Tue Aug 13, 2024 6:47 pm
Man, I think I have modeled it incorrectly. I thought it was fuse then breaker.
File comment: Another example for cb 6
File comment: It's cb 6, 7, & the main circuit breaker.
PostPosted: Tue Aug 13, 2024 11:07 pm
Not sure why it would make any difference. I have a customer with this type of gear and have the shop drawings with factory one-lines I can check but not until Thursday.
You might be right. I can't remember if it's breaker then fuse or fuse then breaker. Again though, makes no difference for anything downstream.
PostPosted: Tue Aug 13, 2024 11:24 pm
Looks like you probably are correct fuse then breaker if I'm seeing this pic correctly.
PostPosted: Wed Aug 14, 2024 1:32 pm
Bus then limiter then breaker according to some old shops I had. You were correct:
