| Author |
Message |
amohammed
Post subject: VFDs Posted: Thu Oct 01, 2009 7:48 am |
Joined: Thu Jun 11, 2009 12:38 pm Posts: 33 Location: Kansas city
How do VFD's with bypasses operate in the event of a fault i.e. are they regenerative or only allow fault currents to flow from line side to load side?
| Top |
Jim Phillips (brainfiller)
Post subject: Posted: Thu Oct 01, 2009 1:32 pm |
| Plasma Level |
In bypass mode, the short circuit motor contribution can backfeed through the bypass back to the rest of the power system. Does it operate in bypass often? Probably not, but it is a good "what if" to consider a case with it directly connected.
_________________ Jim Phillips, P.E. Brainfiller.com
| Top |
[ 2 posts ] |
