It is currently Fri Nov 13, 2026 8:29 pm
 Post subject: Font issue with new site??
PostPosted: Thu May 22, 2014 1:28 am
Hello, it seems all my messages have been changed to a very small size. Anyone else been having problems after the update?
 Post subject: Re: Problems with new site
PostPosted: Thu May 22, 2014 2:31 am
Since I have come here because of a search on Google I modified my size manually so if other people have same question as me and Google it they can understand what is said on this site.
I came across some people with similar problems (not always but in these topics):
viewtopic.php?f=10&t=3127&p=14569#p14569 PaulEngr
viewtopic.php?f=33&t=3185&p=14758#p14758 Larry Stutts
viewtopic.php?f=23&t=3229&p=14974#p14974 GBISON
viewtopic.php?f=9&t=3254 Joel Bucknell
viewtopic.php?f=34&t=2998 Earl
viewtopic.php?f=34&t=3300 Jim Phillips
viewtopic.php?f=23&t=3306 Ryan Tan
viewtopic.php?f=8&t=3310 Mads Andersson
If Jim wants to look into it I have not modified my replies in this topic viewtopic.php?f=32&t=3205
As you can understand I did not check everything only the posts in topics I had to edit posts of my own and it are only reactions not the quotes.
I suggest that if you come across a post with very small letters you post the link and name of poster in this topic. When the poster sees it he can edit it easily.
PostPosted: Thu May 22, 2014 6:21 am
Thanks Luc, we just re launched this morning and didn't catch this one. I meet with our web developer later today to resolve the final (?) items.
 Post subject: Re: Font issue with new site??
PostPosted: Thu May 22, 2014 8:20 am
Just found out what happened. The platform that we migrated from used a font size of 1, 2, 3, etc. which corresponded to to a set size for text but was not really a numerical value of the font.
When we migrated to the new platform, it uses actual font size i.e. 12 pt. etc. and became confused when it saw 1, 2, 3, etc. Most of this was caught and corrected but apparently a few got past us.
If you run into the few remaining cases, you can either adjust the font yourself (if you are the poster) or send an email and we can change it on this end.
Thanks!
