Grounding the circuit
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=2133
Author:  Jim Phillips (brainfiller) [ Sun Mar 04, 2012 8:38 am ]
Post subject:  Grounding the circuit
When establishing an electrically safe work condition, do you also apply grounds to the circuit?
  • Yes
  • No
  • Depends on the situation
Author:  rovinnaki [ Mon Mar 05, 2012 12:14 pm ]
We don't bother earthing out LV circuits but anything MV and above is not deamed Isolated until earths are applied to the circuit.
Dave Sargent
Origin Energy NZ
Author:  gilmomoney [ Fri Mar 16, 2012 10:55 am ]
i second what Dave said...we'll perfrom voltage checks on the LV side and then ground out the MV systems.
Author:  Gary B [ Fri Mar 16, 2012 9:22 pm ]
Has much to do with context. Some facilities are more comfortable with a visible open; i.e: withdraw the breaker; but on systems with overhead distribution lines (exposure to accidental energization or induced voltage) grounding is the norm, always.
