| Author |
Message |
Jim Phillips (brainfiller)
Post subject: Have you ever been burned (from any source) Posted: Sun Oct 06, 2019 2:09 pm |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
PPE and Arc Flash Studies are about protecting the worker from burn injury as a result of an arc flash. This week’s question is about burn injury from ANY source. Arc flash, fire, hot surface etc.
Have you ever been burned? (from any source)
Yes – First Degree Yes – Second Degree Yes – Third Degree No
(Stories are encouraged!)
| Top |
Guest
Post subject: Re: Have you ever been burned (from any source) Posted: Mon Oct 07, 2019 7:17 am |
Soldering iron - first degree and second degree Sunburn - first degree and borderline second degree Campfire - both second degree and first degree
| Top |
arcad
Post subject: Re: Have you ever been burned (from any source) Posted: Fri Oct 11, 2019 6:39 am |
| Sparks Level |
Joined: Wed Jun 10, 2009 5:00 pm Posts: 271 Location: Toronto
Gas stove (probably the first bright memory from childhood) Boiled water СаС2 (aka Carbide) water mixture explosion (burnt eyebrows, eyelashes and fingers) Electric heater Campfire Sunburn
Contrary to widely spread and arc flash industry accepted concept of 1.2 cal/cm2 threshold incident energy to 2nd degree burn, I strongly believe that the scope and severity of burn has nothing to do with the amount of incident energy but with the rate the energy has been delivered.
_________________ Michael Furtak, C.E.T. http://arcadvisor.com
| Top |
Page 1 of 1
[ 3 posts ] |
