It is currently Thu Aug 13, 2026 1:03 pm
For arc flash, do you consider a tie to be fed from both sides in the event it fails
Yes 24%  24%  [ 8 ]
No 62%  62%  [ 21 ]
Depends 15%  15%  [ 5 ]
Total votes : 34
 Post subject: Arc Flash and Tie Failure
PostPosted: Sun Jul 19, 2020 12:58 pm
Here is an interesting question. When modeling a main-tie-main a.k.a. double ended substation where only 2 devices are closed at the same time, would you consider an arc flash at the tie being fed from both sides in the event that the tie fails?
Main-Tie-Main
Yes
No
Depends
Curious about opinions.
