It is currently Fri Oct 23, 2026 8:01 am
Do you/company/client/consultant use a data collection/checklist form?
Yes 74%  74%  [ 20 ]
No 22%  22%  [ 6 ]
N/A 4%  4%  [ 1 ]
Total votes : 27
 Post subject: Data Collection Form/Checklist
PostPosted: Sun Dec 04, 2022 12:44 pm
This one is simple but there is an underlying reason for the question (committee work)
Yes
No
N/A
Your thoughts are welcome!
 Post subject: Re: Data Collection Form/Checklist
PostPosted: Sun Dec 04, 2022 3:59 pm
Only if I don't have a one-line prior to survey.
I like to at least build the model off the existing single line diagram prior to surveying if it's available. Even better if I have shop drawings on the equipment and a power plan.
Field survey is mostly verification that I mark right in/on the model.
If neither are available and I have to collect all the data before modeling anything I have a form on my iPad for data collection with hard copy forms in my backpack as a backup plan.
Edit: it also depends on the size of the job. Very large models can be a little unwieldy on scene so sometimes forms are better depending on the amount of survey needing to be done.
