| Author |
Message |
Jim Phillips (brainfiller)
Post subject: Electrode Configurations - General Discussion Posted: Thu Feb 21, 2019 7:35 am |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
| Top |
bbaumer
Post subject: Re: Electrode Configurations - General Discussion Posted: Thu Feb 21, 2019 10:14 am |
| Arc Level |
HOA ? Attachment:
_________________ Retired but I might visit once in awhile
| Top |
tmpatton
Post subject: Re: Electrode Configurations - General Discussion Posted: Mon May 20, 2019 7:19 am |
• Can the IEEE committee provide videos of the HOA, VOA, VCB, VCBB, and HCB tests on medium voltage (>1kV and <15 kV) equipment? • If the arc is created on the VCB, could a HCB event occur? • If the fault occurs in the middle of the vertical terminals (as circled in blue below in Figure G.40), would the arc go to the end of the conductive material (representing a VCB arc) or stay at the location that the arc was started (producing a HCB arc)? • If the fault occurs in the middle of the vertical terminals (as circled in blue below in Figure G.40), would the arc go to the end of the conductive material (representing a VCB arc) if the terminals were longer in length?
• Based on the description and figures within G.4 of the IEEE 1584-2018, would the application of the standard for HOA and VOA arcs be based on the relative electrode direction (Horizontal electrode configurations – HOA, and Vertical electrode configurations – VOA)? For example in the picture, would a Horizontal electrode configuration be assume as the direction of the energized material is pointing towards the worker/sensor? o Is it reasonable to assume both HOA and VOA are present if the electrode has a bend or has a variety of protrusions/shapes? o How would the equipment manufactures modify the equipment to ensure the arc would go vertical away from the worker?
| Attachments: |
| Top |
Page 1 of 1
[ 3 posts ] |
