| Author |
Message |
FlufflyBunnyFeet
Post subject: IEEE 1584 -2018 - Gaps Between Conductor Posted: Tue Nov 26, 2019 6:43 am |
I have a question regarding the the Gap between the conductor. As you know, in a switchboard the main bus will have a bigger distance between electrodes if compared with the electrodes that connected to the protection unit. Is this Gap related to the electrode configuration, VCB, VCBB, etc? Or is this Gap related to the main bus of the swithboard?
Thanks, Fluffy Bunny Feet
| Top |
JBD
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Tue Nov 26, 2019 8:29 am |
Joined: Mon Jan 18, 2010 11:35 am Posts: 619 Location: Wisconsin
| Top |
FlufflyBunnyFeet
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Tue Nov 26, 2019 10:03 am |
Hey, thanks for the feedback.
What is your opinion?
| Top |
Jim Phillips (brainfiller)
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Tue Nov 26, 2019 1:44 pm |
| Plasma Level |
Joined: Mon Sep 17, 2007 5:00 pm Posts: 1738 Location: Scottsdale, Arizona
Some of the reasons:
Is someone really going to measure the equipment There are multiple gaps for any give piece of equipment
| Top |
FlufflyBunnyFeet
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Tue Nov 26, 2019 2:48 pm |
Hi Jim,
can you please help me in this question? I can have all the measurements, gaps, distances in a specific switchboard, no problem.
| Top |
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Wed Nov 27, 2019 1:22 pm |
| Plasma Level |
JBD wrote: The gap would be related to the point where the arcing is.
I don't know of anyone that puts lots of effort into fine tuning their calculations. I believe most people simply use the default gaps and 2 or 3 electrode configurations, in an effort to determine a worst case condition. JBD Sums it up quite well. I attached a photo from a test set up in the lab. The gap (from the lab) is the distance between the conductors (copper rods in this case). As JBD stated, there can be many different gaps for a single piece of equipment so most use the IEEE 1584 (software) defaults based on equipment type/class. If you want to change the gap in the calculations you can do that as long as it is within the range of applicability of IEEE 1584.
| Attachments: |
| Top |
FlufflyBunnyFeet
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Thu Nov 28, 2019 1:46 am |
Hello Jim,
thanks for the reply.
Please check the attached picture. In this situation i have a busbar along all SWB with a GAp of 111 mm between buses and also have electrodes with gap of 50mm in the connection to the protection unit, in this case the incomer from the source.
Thanks,
| Attachments: |
| Top |
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Fri Nov 29, 2019 8:03 am |
| Plasma Level |
Hope this helps.
| Top |
FlufflyBunnyFeet
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Sun Dec 01, 2019 11:30 pm |
Hello Jim,
Thank you for feedback.
yes, i am also considering the protective device tripping time. This project follows IEC construction and starting to see some big differences between IEC and the North American standard for the switchboard construction. I am measuring very small working distances and big electrodes gaps (for several reasons here) What standard does the North American industry follows for the Switchboard construction?
Once again, thanks for you support. Fluffy Bunny Feet
| Top |
MarceloEValdes
Post subject: Re: IEEE 1584 -2018 - Gaps Between Conductor Posted: Mon Dec 02, 2019 8:55 am |
| Top |
Page 1 of 1
[ 10 posts ] |
