It is currently Sun Jul 26, 2026 11:52 pm
 Post subject: When spell check isn't enough
PostPosted: Fri Jul 27, 2012 12:05 pm
I downloaded a Fluke white paper which had the following:
"to reduce the indecent energy on the body"
Something I hadn't considered.
PostPosted: Fri Jul 27, 2012 12:38 pm
We don't have a "best post of the day" award but if we did, this would be it. :)
PostPosted: Mon Jul 30, 2012 6:55 am
Did you attach the white paper?
PostPosted: Mon Jul 30, 2012 7:03 am
Here is a link
http://link.pentonconst.com/u.d?SYGrsQLFM4ypWT8Pk-Vw8=1141
PostPosted: Tue Jul 31, 2012 12:29 pm
I send an email to Fluke. They are on top of it. Their reply:
"We're trying to track down the author of this application note. We have not found the term "indecent energy" in other publications."
PostPosted: Tue Aug 07, 2012 9:38 am
Indecent Arc Flashing has been around since the 70s. Derived from “Arc”hie Bunkers’ days of a blooper, well publicised but never aired, between Meathead and Archie.
It must be noted that special labeling for equipment subject to indecent flash is required. Labels must be located between 36 and 42 inches above the floor, at least 6 inches square, 7 for usually high energy situations. Both front and back sides of the equipment must be labeled especially if the equipment is over 50 years old. Safety distances vary, depending upon the age of the technician, See OOPSHAs’ website.
PostPosted: Wed Aug 15, 2012 5:11 am
Link to a GE article:
http://www.geindustrial.com/Newsletter/current_transformer_paper.pdf
At least 3 mentions of "current caring devices".
I didn't know they cared.
PostPosted: Wed Aug 15, 2012 6:43 am
The safety distance will depend on the so called 'arc length' of the indecent flasher and the visual acuity of the person looking at it. For example, a typical arc length and 20-20 vision requires a distance of approximately 25 meters to reduce mental scarring to an acceptable level.
PostPosted: Fri Aug 17, 2012 11:33 am
They took a stab at it:
We are referring to a Arch Flash that would cause a burn.
I'm not sure if they passed or failed the Turing Test.
I'm still trying to figure out what the appropriate PPE would be.
PostPosted: Tue Aug 21, 2012 10:43 am
This is great! I think I finally understand it all now. :D
PostPosted: Fri Sep 21, 2012 5:12 am
The general electrical might have a solution to this and the sight is full of innovations at its best for as the company is well renowned for its innovations and experiments. Seriously I have never heard of such term ever before.
