It is currently Sun Sep 27, 2026 7:53 am
 Post subject: CSA Z462 Implementation of IEEE 1584 2018
PostPosted: Wed Feb 20, 2019 7:53 pm
I'm wondering if anyone here from Canada are now using the latest IEEE 1584? Should it be implemented right away or should we be waiting for the next revision of CSA Z462?
 Post subject: Re: CSA Z462 Implementation of IEEE 1584 2018
PostPosted: Thu Feb 21, 2019 11:32 am
Hi,
Most are updating arc flash studies as part of the 5 year review cycle from NFPA 70E. CSA Z462 is based on NFPA 70E.
Also, quite a bit needs sorted out regarding the application of the new standard and updated software. Below is a survey from a short time ago regarding when people will be updating. 80+ percent responded they will update based on the review cycle.
https://brainfiller.com/arcflashforum/viewtopic.php?f=33&t=4816
Hope this helps.
PostPosted: Fri Feb 22, 2019 8:07 am
We started using rev. 2018 for all new project, including 5 years updates.
Knowing how much the new revision produce results closer (more accurate) to realistic situations, I feel it is our professionnal duty to use the new revision.
Also, section D.4.1 of Z462 asks users to consult the latest revision of 1584.
