It is currently Tue Nov 24, 2026 5:09 pm
Have you performed arc flash calculations manually using?
Yes - 2002 Edition IEEE 1584 27%  27%  [ 12 ]
Yes - 2018 Edition IEEE 1584 27%  27%  [ 12 ]
Yes – Other methods such as Lee equations 25%  25%  [ 11 ]
No 20%  20%  [ 9 ]
Total votes : 44
 Post subject: Arc Flash Manual Calculations using IEEE 1584
PostPosted: Sun Nov 29, 2020 2:26 pm
The equations in the 2018 edition of IEEE 1584 are more complex than the 2002 edition. Have you ever performed arc flash calculations manually using either the 2002 or 2018 edition?
Here is the question:
No
Select all that apply
 Post subject: Re: Arc Flash Manual Calculations using IEEE 1584
PostPosted: Sun Nov 29, 2020 2:28 pm
Both the 2002 and 2018 calculations in Jim's class. I'm not sure that I have recovered. Quite complex.
PostPosted: Sun Nov 29, 2020 4:27 pm
Oops. Yes there is quite a bit to it as you found out.
