It is currently Sat Aug 01, 2026 9:40 am
 Post subject: Maintenance mode and PPE
PostPosted: Tue Jun 29, 2021 3:24 am
We are installing a new maintenance mode switch on a gear and I was asked if while in maintenance mode, could they use different level PPE that is dependent on the switch being activated. My first thought was yes, as part of the JSA or maintenance procedure they could verify its in Maintenance mode and then proceed based on the lower IEs. That would mean two different stickers on this gear however and could cause confusion.
How do most people handle this? Is the maintenance mode just a mitigation device and still require worst case PPE or have two different levels of PPE for each gear? any literature to back this up?
 Post subject: Re: Maintenance mode and PPE
PostPosted: Tue Jun 29, 2021 10:38 am
My customers usually put a single 'worst case' label on the equipment. They kept the maintenance switch values with the report. A person qualified to implement the maintenance switch would know where to go to find the appropriate PPE.
PostPosted: Tue Jun 29, 2021 10:39 am
mpparent wrote:
ERMS switch use should be in a MOP and the AFIE documented that way. Helps avoid confusion...
I agree.
PostPosted: Mon Jul 19, 2021 7:39 am
I would label with worst case operating incident energy level only. Use arc flash maintenance switch as an additional layer of arc flash reduction, even with the worst case PPE being used.
PostPosted: Mon Jul 19, 2021 11:59 am
Too much PPE can cause a safety problem, such as limiting visibility, movement, and causing heat stress. Worst case might end up being worse.
PostPosted: Tue Jul 27, 2021 10:39 am
What you may want to consider is as part of your in-house roll out training, I am sure that you are instructing your workers on how to read and interpret your detailed warning labels for arc flash and shock. As part of this, explain the ARMS and briefly what it does in mitigating the IE. From there, explain the label and how the IE rating is less when the ARMS is engaged versus not engaged. I think that you may find this is a good exercize for them. I hope that this helps
PostPosted: Mon Nov 22, 2021 1:41 pm
We use maintenance mode on switch gear breakers to reduce incidence energy on downstream MCC units typically. We have a dual label for that purpose. That way they have an option ask to what PPE level to wear based on using maintenance mode or not. We do recommend using maintenance mode when doing any activity at the MCC including switching disconnects.
PostPosted: Sun Apr 13, 2025 3:57 am
The AF study indicates IE levels with and without ERMS. Ideally, the label should be showing IE level without the ERMS on the main IE levels section. On the "note" section, reduced IE level and ERMS location should be indicated.
And yes, you should be using PPE based on the reduced IE levels.
PostPosted: Tue Apr 22, 2025 4:32 pm
I've noticed that oftentimes the maintenance mode setting is of no labeling benefit because the arcing current is already in the instantaneous region of the breaker curve.
It might be of some practical benefit if the actual arcing current from a real event is lower than the calculated value, if the actual real world current was in the maintenance mode instantaneous band but not in the normal mode band.
95% Retired
