It is currently Tue Aug 11, 2026 4:00 am
Have you worked with renewable energy systems? What types?
None 20%  20%  [ 14 ]
Solar 34%  34%  [ 24 ]
Wind 17%  17%  [ 12 ]
Geothermal 10%  10%  [ 7 ]
Biomas 4%  4%  [ 3 ]
Hydro 9%  9%  [ 6 ]
Tidal/Ocean 3%  3%  [ 2 ]
Other - Specify 3%  3%  [ 2 ]
Total votes : 70
 Post subject: Work with Renewable Energy?
PostPosted: Sun Jan 30, 2022 2:37 pm
I am at an IEEE meeting this weekend and had a long discussion about renewable energy systems and safety. That prompted this week's question.
Select all that apply.
None
Solar
Wind
Geothermal
Biomas
Hydro
Tidal/Ocean
Other - Specify
 Post subject: Re: Work with Renewable Energy?
PostPosted: Thu Feb 10, 2022 9:53 pm
I worked specifically on a solar inverter, but the inverter was supposed to do wind and tidal as well. It also was able to use battery power as well.
PostPosted: Mon Oct 03, 2022 12:11 pm
I am at an IEEE meeting this weekend and had a long discussion about renewable energy systems and safety. That prompted this week's question. Have you worked with renewable energy systems? What types?
Yes, with several types: Photovoltaics and Energy Storage: Lithium Battery, Flow Battery, Flywheel, Thermal. All this from residential to utility-scale installations.
~doug
PostPosted: Fri Oct 21, 2022 7:17 pm
Not sure if this counts as renewable, but I worked on a downhill conveyor that regenerated power by a VFD.
PostPosted: Mon Oct 24, 2022 10:01 am
I would think a regenerative downhill belt conveyor would not necessarily be a renewable energy source. We see this sort of thing in EV regenerative braking as well. I believe this would mainly fall under the heading of system efficiency. Plus the electrical safety aspects should be well covered by VFD safety standard, I should think. ~Doug
