It is currently Thu Aug 13, 2026 2:48 pm
Post new topic Reply to topic Go to page 1, 2, 3, 4  Next
 Post subject: What Software Do You Use?
PostPosted: Sun Jul 11, 2010 4:53 pm
Hello!
First post and wanted to find out what the majority of the electrical people here use for Arc Flash Calculation software.
I have only used SKM and have found my work interesting sometimes when it comes to protective devices and proper settings.
PostPosted: Mon Jul 12, 2010 5:40 am
With a previous employer I used ESA. I am now in the process of learning SKM.
PostPosted: Thu Jul 15, 2010 6:36 am
In the process of learning Etap.
PostPosted: Thu Jul 15, 2010 11:51 am
I've been useing EasyPower for a couple of years,
PostPosted: Thu Jul 15, 2010 12:20 pm
I would like to learn ESA. Coming from SKM how easy/hard would that be, in your opinion?
PostPosted: Thu Jul 15, 2010 12:34 pm
I would say that ESA was probably an easier program to use, very user friendly. You should have no trouble at all learning the ESA system.
PostPosted: Tue Jul 20, 2010 7:26 am
SKM PTW 6.5.1.4 W/ 1000 BUS, CAPTOR, DAPPER, FAULT, and Arc Flash
PostPosted: Tue Jul 20, 2010 4:03 pm
It looks like somebody needs to do a few updates!
:rolleyes:
PostPosted: Wed Aug 11, 2010 1:17 pm
Does anyone here have any input on ArcAd's Analytic version 4.1 software?
PostPosted: Tue Aug 17, 2010 12:29 am
Arc Flash Program
I use the SKM software. I have been using it since it was in DOS OS. I love this program, especially all the output options to deliver to the customer a (not only technically sound result) but with a great image.
PostPosted: Wed Aug 18, 2010 6:31 pm
I use Etap, and I think it's great software; however, I don't have any familiarity with any other.
PostPosted: Thu Aug 26, 2010 3:53 pm
I use Paladin DesignBase by EDSA. I have found it very easy to use compared to SKM or ETAP.
PostPosted: Wed Sep 01, 2010 1:31 pm
Arc Flash Analytic Software
I've been using Arc Flash Analytic version 3.2 both for the analysis and labeling.
Michael Furtak, C.E.T.
http://arcadvisor.com
PostPosted: Sun Sep 19, 2010 12:49 pm
Modelling Software-SKM Rules!
I have personally been using SKM for many years. One of my mentors has been using it since the DOS days. It seems to have a very good library and general acceptance in the industry. Some of my clients have used EasyPower. When modeling older plants, SKM seems to have excellent customizaton capabilities; e.g. when you have, say, an older AK-type breaker and are going to retrofit it with a new trip unit, it is relatively easy to make a hybrid combination low voltage circuit breaker with all of the correct ratings, settings, data and parameters included. If you get into something really strange, Yogi or one of the other guys in the SKM library group can help you out or do it for you. Many manufacturers can send you their SKM library file to include in your custom library. The TCC reports are also customizable. On large systems, I have had to export the one-line files (showing ANSI SC, Load Flow, Arc Flash results etc.) to AutoCAD and do some formatting so that it is easily readable for clients.
PostPosted: Wed Sep 22, 2010 11:05 am
I currently use ETAP. Their Arc Flash Result Analyzer is much better than any other one I have tried.
PostPosted: Thu Sep 30, 2010 1:00 pm
I am using EasyPower. I have found it to live up to its name and the support is incredible. They are very, very responsive to questions and making additions to the library. It is also easy to add say a microprocessor trip unit to an old AK breaker.
PostPosted: Thu Jan 06, 2011 9:29 am
Skm ptw32.
PostPosted: Thu Jan 06, 2011 12:48 pm
I use SKM but another client wants us to use etap. So I guess I have to learn another program.
PostPosted: Fri Jan 07, 2011 3:14 pm
I am in the process of switching from SKM to ETAP.
PostPosted: Fri Jan 07, 2011 3:17 pm
Curious to know why you are switching? I have heard good things about SKM and I think between SKM and EasyPower, those seem to be the most popular.
Post new topic Reply to topic  [ 61 posts ]  Go to page 1, 2, 3, 4  Next
